I am not able to change the photos of the demo pages "About me - Alex", "Services - Two columns" etc. I really don't know where to find the picture to change and tried with "Featured picture", "featured album", "background image".... Where can I change them?
Thank you for your help and best regards,
I.
Glad you did it.
For anyone wondering - it was background of row in Visual Composer.
please provide login credentials to admin panel, send it via private message.
I'll take a look and try to make it clear for you.
1. you have Visual Composer 5.0 - the latest version is 5.0.1 and probably next FatMoon update will be equipped with the latest Visual Composer version. This is not an issue.
2. as for being able to change the background - just checked that. It's working correctly on your website. Click the 'pencil' icon (marked with red rectangle to the right), then find 'Background' setting in 'Design Options' tab.
Air was referring to situation when you want to have background with parallax effect.
3. you have some extra plugins installed. This can be a problems source in the future, so please report issues after disabling all extra plugins and making sure that the issue really exists.
If you feel uncomfortable doing so - please provide screenshots of steps you make in order to set the background.
Maybe you have obsolete web browser?
Can you provide info about the device/system/browser you're using? With version numbers.
Did you try on another device?
We both login with same credentials, we both edit same page, both click same button and we get different effects...
Are you familiar with Developers Tool in Chrome? You could check if you are getting any kind of error messages after clicking 'pencil' icon.
