Is it possible:
1) to set the direction of the movement of slides (Transition type - zooming);
2) to make smooth transition between slides (now they change very sharply);
3) to put video at backgrond (fullwidth), i know about gif, but the size of gif animation is to big;
4)to change the color of "Gradient above photos";
Thank you for the help.
1. Nope, it is random.
2. They should be smooth. Could you show link?
3. Just chose video instead of image when adding media
4. Not so easy as there many different rules for different browsers. You can use this topic as reference and use generator linked in there to change color.
1. it is a pity
2. https://pobeda.life/
3. I use it now (slide 6), it doesn't start automatically, it doesn't appear on full screen, when video start playing all menus disappeares. Maybe I do something wrong?
3a. Have you enabled autostart for this video? See whole section http://apollo13.eu/docs/photon/#!/add_new_album for more details.
3b. Layout hides on play so user can have access to video controls, like progress bar or volume.
Is it possible to disable access? Just video on background. Just if I use gif instead image. (gif is to big size..).
Yes, it works. Thank you.
http://apollo13.eu/docs/photon/#!/albums_menu
