Hello, i deactivate the menu, so i have only my logo on the header. In my computer, the logo appears on the second slide with the top bar behind. But on mobile and tablet, the logo appears without the top bar. How can i do to keep the top bar and the logo on mobile without activate the menu ( it is a one page site).
Thanks.
Yes, live link would help a lot to understand your situation, cause it is not easy to understand just from description.
As for top bar you have option to disable/enable it for mobile, so make sure you have it enabled :
Customizing ▸ Header settings > Top bar > Display it on mobiles
I dont ' why. I want to have the top bar on mobile and tablet with the logo. How can i do ?
