Cart Button Color
edited July 2014 in Fame Posts: 7
Hey there! I recently purchased the Fame theme and I'm having a lot of fun playing with it, but I'm having some difficulty adjusting the color in the cart button. I'd appreciate it if someone could point me in the right direction!
Thanks,
Ray
www.elicitco.com
    Hello
    This button can changed in panel here http://apollo13.eu/docs/fame/#!/buttons_colors
    This will change however color of all buttons in theme. If you need specific CSS only for this button then I will prepare it for you:-)
  • edited July 2014 Posts: 7
    You're AWESOME! Sorry in advance for the noob question regarding that button. Would it be possible for me to actually remove it? I'm going to move the link to the shopping cart to the top bar.
    Thank you so much for your help!
    Post edited by RaymondCulbertson on
    If hiding by CSS is good for you then you can do it by adding this custom CSS:
    .wc-header-cart a.a13-button{
        display: none !important;
  • Thanks for your help! I placed the code in custom css, but I'm not completely sure I've done it correctly. If you could take a look at the site to see what I mean, that would really help. I really appreciate your help.
    Ray
    www.elicitco.com
    Yes you have added it properly, but:
    - you have also some code like this there [featured_products per_page="4" columns="4" orderby="date" order="desc"] - it shouldn't be there.
    - You have somehow broken HTML in this cart, but I have seen that before you made changes in CSS. Have you made any changes in PHP files?
  • I think my buddy might have tried to remove the button by going into the editor in wp.. that's when that button started looking funny.
    So you will have to overwrite changed files with originals from theme installation file. Probably file fame\advance\utilities\woocommerce.php
  • I'm feeling pretty embarrassed, now. I tried overwriting the woocommecerce php file, but no success there. Ultimately I ended up reinstalling the theme in an attempt to just get a fresh start, but everything stayed exactly the same as it was before.
    Ray
    When I view it, it looks good now. Maybe you didn't clear browser cache, or have some cache plugins in WP?
  • I actually ended up resetting wordpress and starting from scratch. I inputted the code in custom css, but the button still remains. =(
    Hold up :-) Maybe I didn't understand which part exactly you want to hide. Cause we have hidden button in mini-cart in top right corner. Maybe you wish to hide all that mini cart?
  • haha yes, that's exactly what I want to do!
    Then for pure CSS hide try:
    #wc-header-cart{
