Hey there! I recently purchased the Fame theme and I'm having a lot of fun playing with it, but I'm having some difficulty adjusting the color in the cart button. I'd appreciate it if someone could point me in the right direction!
Thanks,
Ray
www.elicitco.com
This button can changed in panel here http://apollo13.eu/docs/fame/#!/buttons_colors
This will change however color of all buttons in theme. If you need specific CSS only for this button then I will prepare it for you:-)
Thank you so much for your help!
Ray
www.elicitco.com
- you have also some code like this there
[featured_products per_page="4" columns="4" orderby="date" order="desc"]- it shouldn't be there.- You have somehow broken HTML in this cart, but I have seen that before you made changes in CSS. Have you made any changes in PHP files?
Ray
#wc-header-cart{With regards.display: none !important;
