if( jQuery(this).parent().hasClass('scroll-to') && jQuery(this).parent().hasClass('menu-item-has-children') && !jQuery(this).parent().find('.sub-menu, ul.children').hasClass('open') ){
if( jQuery(this).parent().hasClass('scroll-to') && jQuery(this).parent().hasClass('menu-item-has-children') && !jQuery(this).parent().find('.sub-menu, ul.children').hasClass('open') && !jQuery(this).parent().hasClass('hovered') ){
thank you very much for this report, this bug will be fixed in upcomming update.
For now you can fix it by editing scripts.js file located in wp-content/themes/adamant/js/ folder.
Find this line: and replace it with this line: please be careful, and make sure that you've copied whole line.
FYI - new update is available, top level menu items work as they are supposed to.
