After switching permalinks on to "/%postname%/" or "/%category%/%postname%/", "The Blog" and "404", which are pages are 404. I'm pretty sure it's something silly, please advise.
Hello Wojciech, as far as i know, there are few possible reasons for situation you get, so the research field is wide. Try to google 'wordpress 404 after changing permalinks' and you'll find a lot of cases with solutions. You'll find something useful for sure.
I already did. ".htaccess" is correct, normally Wordpress for my custom structure should create automatic redirects, so it is highly possible that theme/plugins (I can't deactivate "WPbakery and Visual Composer") are causing it. Aren't there any other threads like that by now?
Hi, It was a silly error. On my hosting provider panel you need to click "sync .htaccess" to make it actually happen... Maybe somebody else will have similar issues. Thanks!
This discussion has been closed.
