Hello i testet my site www.grau-wild.de today with an iphone 5 and 6. on both i have the problem that people and portfolio will be displayed with 2 columns on your demo only with one.
on iPhone 5 i have additionally the problem that my first heading isn't centered correctly and the clients slider didn't word, the images are not centered and the slider didn't exist, on iphone 6 it works. Slider also didn't work in your demo with I5, headings in your demo are correct on the I5.
I have also removed my complete custom css for testing.
Hi, as for Works and People - there's small glitch which I'll fix in upcoming update.
as for Headings - the issue is caused by long words (which is typical for german language). You can try add h1{
wordr-wrap:break-word;
} into Chillout Options >> Custom Style, but it's not perfect solution. OR change font-size for smaller devices - try this:
@media only screen and (max-width: 420px) {
h1{
font-size:20px;
} it should work (including iphone 6+)
as for slider - thanks for report, is not working below certain screen width, I'll fix that also.
Stay tuned for update, I'll let You know.
h1{ wordr-wrap:break-word; }into Chillout Options >> Custom Style, but it's not perfect solution.
OR
@media only screen and (max-width: 420px) { h1{ font-size:20px; } }it should work (including iphone 6+)
how long will it took for the new update?
i updated the theme
the paddings from menu and footer are ok now
but the problem with the pictures/portfolios still exist, the slider still didn't work on iphone 5 ---(and the other headings now have problems)---
i testet it on a real iphone and on this site http://iphone5simulator.com/
You forgot to update 'Visual Composer extend by Apollo13 for Chillout' plugin.
Don't work on your demo and on my site.
thanks, You're right.
I've fixed that already, we'll soon release next update.
Chillout is in 1.2.4 version.
Is that correct?
Thanks for quick support.
