Mobile Problems
edited February 2015 in Chillout Posts: 63
Hello
i testet my site www.grau-wild.de today with an iphone 5 and 6.
on both i have the problem that people and portfolio will be displayed with 2 columns on your demo only with one.
on iPhone 5 i have additionally the problem that my first heading isn't centered correctly and the clients slider didn't word, the images are not centered and the slider didn't exist, on iphone 6 it works.
Slider also didn't work in your demo with I5, headings in your demo are correct on the I5.
I have also removed my complete custom css for testing.
Post edited by Tim92 on
    as for Works and People - there's small glitch which I'll fix in upcoming update.
    as for Headings - the issue is caused by long words (which is typical for german language). You can try add
    h1{ wordr-wrap:break-word; }
    into Chillout Options >> Custom Style, but it's not perfect solution.
    OR
    change font-size for smaller devices - try this:
    @media only screen and (max-width: 420px) { h1{ font-size:20px; } }
    it should work (including iphone 6+)
    as for slider - thanks for report, is not working below certain screen width, I'll fix that also.
    Stay tuned for update, I'll let You know.
    german is toooooo long :D
    how long will it took for the new update?
    I think it will come out today.
    FYI - new version is available.
  • edited February 2015 Posts: 63
    Hi
    i updated the theme
    the paddings from menu and footer are ok now
    but the problem with the pictures/portfolios still exist, the slider still didn't work on iphone 5 ---(and the other headings now have problems)---
    i testet it on a real iphone and on this site http://iphone5simulator.com/
    1028 x 448 - 27K
    308 x 453 - 88K
    The font is now ok i decreased the size of it.
    You forgot to update 'Visual Composer extend by Apollo13 for Chillout' plugin.
    Ok updated it to 1.07, the portfolio works but the slider is still broken on iPhone5.
    Don't work on your demo and on my site.
    thanks, You're right.
    I've fixed that already, we'll soon release next update.
    where is the new version? i installed the vc apollo plugin new but its the same version and on theme forest isn't a new version of chillout
    Visual Composer extend by Apollo13 is in 1.0.8 version
    Chillout is in 1.2.4 version.
    Is that correct?
    Normaly Themeforest notifies me on an update but it doesn't, updated is installed an works.
    Thanks for quick support.
