visual composer updated again and issue in theme occured again.
As last time now visual composer has been updated on 1st September . theme is showing issue again as i cannot add content into the page. cannot add or edit content. Nor i can remove any.
please check this issue.
    Please provide me an url to your website.
    1. The latest Adamant is now in 1.5.1 version.
    2. When did You notice this problem? Did You updated any plugin?
    3. If it's ok for You - please provide me login credentials to admin panel (do it ONLY via private message), I'll take a look at your installation.
  • i m messaging you private.
    I can't confirm any issues.
    I can edit page, save it, change it, and display changed without any problems.
    Please provide specific screenshots with description of what's wrong.
  • on homepage. i cannot add new rows.
    i tried to edit columns.
    but failed to do so
    OK, I can see now.
    There's a JavaScript error caused by js composer which version is 4.5.1 on your installation.
    Please update Adamant to version 1.5.1, it's equiped with Js Composer v 4.5.3
  • ok i do it
  • hi
    i have updated theme.
    still there is error in the columns.
    few rows doesnt show up at all.
    few have abnormal spacing and i cnt see the row settings to correct the spacings.
    same website. you have the logins.
  • edited September 2015 Posts: 6
    cancel
    Post edited by Matt1980 on
    Try to deactivate all extra plugins (not bundled with theme) and see what will happen.
  • deactivated all plugins. still not able to see my content to edit
    I've found the problematic element. It 'Raw HTML' shortcode with Youtube subscribe button, which is next to 'Facebook like'.
    I'm not yet sure why it's happening, I'm running tests to find what's wrong.
  • i m using raw html code which youtube gives it self. can you find out why its causing issue?
    this code is put since the web is made but now its causing problem.
  • update?
    Well, there was a typo in page's coding, is must had happened when something went wrong while saving the page. It's ok now. I have check.
    Please check it for You and confirm.
  • alright
    done its wokring fine.
    Okay, I am getting the same issue. Visual Composer does not allow me to select elements for editing. Just purchased this about a week ago.
    Greg said: Okay, I am getting the same issue. Visual Composer does not allow me to select elements for editing. Just purchased this about a week ago.
    Hi Greg. Please start new thread, You can't be sure if this is the same issue unless it's fixed. Also read this: http://support.apollo13.eu/discussion/12/before-you-ask-read-this#latest and provide all necessary data.
