As last time now visual composer has been updated on 1st September . theme is showing issue again as i cannot add content into the page. cannot add or edit content. Nor i can remove any. please check this issue.
1. The latest Adamant is now in 1.5.1 version. 2. When did You notice this problem? Did You updated any plugin? 3. If it's ok for You - please provide me login credentials to admin panel (do it ONLY via private message), I'll take a look at your installation.
I can't confirm any issues. I can edit page, save it, change it, and display changed without any problems. Please provide specific screenshots with description of what's wrong.
OK, I can see now. There's a JavaScript error caused by js composer which version is 4.5.1 on your installation. Please update Adamant to version 1.5.1, it's equiped with Js Composer v 4.5.3
hi i have updated theme. still there is error in the columns. few rows doesnt show up at all. few have abnormal spacing and i cnt see the row settings to correct the spacings. same website. you have the logins.
Hi, I've found the problematic element. It 'Raw HTML' shortcode with Youtube subscribe button, which is next to 'Facebook like'. I'm not yet sure why it's happening, I'm running tests to find what's wrong.
i m using raw html code which youtube gives it self. can you find out why its causing issue? this code is put since the web is made but now its causing problem.
Well, there was a typo in page's coding, is must had happened when something went wrong while saving the page. It's ok now. I have check. Please check it for You and confirm.
i tried to edit columns.
but failed to do so
done its wokring fine.
