Hi my friend,
after your new release (i cannot say if the last one or the previous one) the plugin woocommerce advanced product label plugin is not working anymore (and I really need it)...
I've already checed all plugin and changed theme... it's just not working if I use Fame Theme...
Is there anything you can do about it?
Do you need the plugin to see it?
website www.italiaamoremio.it
gabriele
Isn't it plugin that we already was making custom CSS for it?
By not working you mean something special?
I need more details what it should do and what is happening now.
https://www.dropbox.com/s/teze04pu811r0hq/screenshot_woothemes_3.jpg?dl=0
But nothing happens... https://www.dropbox.com/s/nyzphspq9uhzvnp/screenshot_woothemes_2.jpg?dl=0
It was wroking fine till some time ago, but as you can see I do not have label...
You sent me css for the upper side of the image... :-)
I don't know what changed in theme that could prevent it from working. Have you updated your customiezed templates after updating theme? I believe all details are in this topic http://support.apollo13.eu/discussion/3283/display-products-discount-percentage#latest
is a totally different matter... it's another label the one not working... for this reason I opened a new post...
Let me make a screenshot without Fame theme....
anyway here the screen shot with twenty fifteen theme.. and the label is there..
https://www.dropbox.com/s/3al7qdhrqee6abz/screenshot_apollo_3.jpg?dl=0
I've also tried to delete all css I have in the custom css field, but it's not working...
Then probably it needs same treatment as previous one. However if you say it were working before and now it is not, then it is still strange.
Please show this screen shot, and if you can attach here zip with plugin, thanks. I will remove it as soon as I will download it.
EDIT
Mainly this http://support.apollo13.eu/discussion/comment/13149/#Comment_13149
and probably this http://support.apollo13.eu/discussion/comment/13179/#Comment_13179 (no CSS changes)
it was this one before line 106 do_action( 'woocommerce_before_shop_loop_item_title' );
in content_product...
I thought that one was only for the other label.. the upper one
I own you a donuts for your time... :-)
