The header isn't refreshes on LTR-RTL language change of WPML plugin, so there are layout and text direction problems after language switch.
Link:
http://new.millos.co.il/collections/ change language to Hebrew and you'll see the problem. After refresh of the page - the layout and text is ok.
Works fine for me. What browser do you use?
You can always switch off AJAX to make sure page will be reloaded http://apollo13.eu/docs/thirteen/#!/ajax_settings
Hello )
switching off AJAX isn't good option for me.
the problem is on Chrome Version 47.0.2526.106 m
Screenshots included .
red marks - the problem after RTL > LTR switching
normal:
red marks - the problem after LTR > RTL switching
normal:
Anyway by default changing language reloads page anyway, cause there is too much changes for just AJAX reload. In this case somehow link is not recognized properly and this produce issues. On your front page language switching works fine. I will check what can be wrong with pattern recognition.
EDIT:
OK I see where is exactly the issue, that language links are reloaded with AJAX. Now just have to solve it somehow and it will be ready to be added to update :-)
I switched AJAX off till the update and it's worked.
But I have another question about RTL-LTR:
What is the proper way to make RTL version with sidebar on the right and LTR version with sidebar on the left?
I can think of option to add setting for RTL languages that will overwrite default setting.
Is this option you're mentioned will make the option for LTR RTL sidebar be in his place on each language? If so - it'll be great.
Is it still in progress? I wait for that feature )
But it failed to update via plugin and after manual update via FTP (delete-upload) i have this:
Fatal error: Allowed memory size of 377487360 bytes exhausted (tried to allocate 81 bytes) in /mounted-storage/home126/sub026/sc74181-MKUZ/new/wp-includes/template.php on line 554
Please help ) The backend is ok.
I have just retested theme with WPML active and works fine for me.
WP ver 4.4.1
PHP 5.4
Fatal error: Allowed memory size of 377487360 bytes exhausted (tried to allocate 1920 bytes) in /mounted-storage/home126/sub026/sc74181-MKUZ/new/wp-content/themes/thirteen/front-page.php on line 37
For some reason your home page returned wrong name as its template name, and site landed in infinite loop. I have to resave your home page(Edit->Updatae) and now it returns proper name. Have you done some fancy import lately, cause this is only reason I can think of that could mess this. Anyway I will add protection for such case so it will never again go to infinite loop in such case.
Thanks for help.
Customizing ▸ Global Layout
Header - Main Settings - Header variant on RTL languages
http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#updates
http://apollo13.eu/docs/thirteen/#!/installation_update_update_theme
