sticky / fixed work info in works
tiutiu
in FatMoon Posts: 13
Hi
I would like to have a fixed sidebar with the work info but I can't find in the option how can i do that.
I also tried to check the demo that I imported but I can't figure out how do that.
here is what I mean
http://madison.fatmoon.kinsta.com/work/flat-ul-kit/
thank you so much
    If you add any Work info sidebar will then appear :-)
    836 x 650 - 23K
  • tiutiu
    Hi I did it but it doesn't work.
    if I keep only the media grid and I remove the text content, the work info is not fixed and it moves with the content of the page.
    I hope you get what I mean.
    Could you show me link to your work, cause I am not sure that we mean same things.
  • tiutiu
    http://bit.ly/2kdJrR5 here is the link.
    As you can see the work info n the right are not fixed, and when you scroll they move with the content of the page.
    Thank you
    Yes I can see. Thanks for the link.
    Problem is caused as you said:
    tiu said: if I keep only the media grid and I remove the text content, the work info is not fixed and it moves with the content of the page.
    Media grid doesn't have any height while it loads and that what confuses script for sticky sidebar.
    I am working on fixing it. I will reply here later with solution.
  • tiutiu
    so I can fix it with css?
    edited February 2017 Posts: 10,970
    Damn I wrote reply week ago and it didn't go live, sorry.
    Here is my reply:
    OK so I found where exactly was the problem and it was partly in plugin that we use for that sticky sidebar. Fix is bigger then single code line change so it will be added in next update, and then it will work fine.
    Thanks for your help with fixing this issue!
