Hi
I would like to have a fixed sidebar with the work info but I can't find in the option how can i do that.
I also tried to check the demo that I imported but I can't figure out how do that.
here is what I mean
http://madison.fatmoon.kinsta.com/work/flat-ul-kit/thank you so much
If you add any Work info sidebar will then appear :-)
if I keep only the media grid and I remove the text content, the work info is not fixed and it moves with the content of the page.
I hope you get what I mean.
As you can see the work info n the right are not fixed, and when you scroll they move with the content of the page.
Thank you
Problem is caused as you said: Media grid doesn't have any height while it loads and that what confuses script for sticky sidebar.
I am working on fixing it. I will reply here later with solution.
Here is my reply:
OK so I found where exactly was the problem and it was partly in plugin that we use for that sticky sidebar. Fix is bigger then single code line change so it will be added in next update, and then it will work fine.
Thanks for your help with fixing this issue!
