List of ACTIVE plugins. There are any plugins active Wordpress version. My wordpress version is 3.4.2 Theme version you have downloaded. The theme version of airlock is the last one 1.7
OK you look safe. So now please send me login access to your WP via private message here on forum, and I will try to look inside what could be doing it.
last question before you will do above things - are you sure you are NOT uploading whole zip file form themeforest? You should upload only zip file with theme (airlock.zip)
Please add info as explained here http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#Item_1
Don't know here the problem comes from.
