OK I think I know - you have to switch grid element template to one from theme. Edit your post grid and switch to Item Design tab and next select Apollo13 Post, see screen shot:
I already told you another day, when the Excerpt field of any post is empty "read more" appears if it has text, "read more" does not appear and I need it never to appear.
This is element from WPBakery, post grid, right?
Could you give me link to that site?
Please log in to forum to reply:-)
I am not sure if this will be solution, but your message directs me to thinking it should be :-)
Add this in your functions.php in theme, and check will it be better.
I have just tested it with basic grid post, and it hides our "read more".
Place it in functions.php in child theme like on screen shot
See my home page, in "ÚLTIMES NOTÍCIES" posts
Your code days ago that I have it.
I just suspect that maybe code is misplaced, or something that it doesn't work for you in case of Basic grid.
Could you show me screen shot of your child theme functions.php, maybe I will be able to spot what might be wrong.
Another idea: try removing another filter with this code: This is only other place that produce such "read more" link.
