READ MORE PROBLEM IN BASIC GRID.
Hi
I have a "Read more" which appeared on my blog list, in basic grid.
I use the "more" tag in spanish but now two texts appear.
Thank you !!
    This is element from WPBakery, post grid, right?
    Could you give me link to that site?
    crispatitus saidYes, from WPBakery. post grid.
    This is curious, if you leave the extract field in blank “read more” show, but if you put any text in extract field only “leer más” shows.
    Show this in “Ultimes noticies” : http://lourdesfisa.webigrafica.com/
    Hey:-)
    Please log in to forum to reply:-)
    I am not sure if this will be solution, but your message directs me to thinking it should be :-)
    Add this in your functions.php in theme, and check will it be better.
    add_action('after_setup_theme',function(){
        remove_filter( 'the_excerpt', 'apollo13framework_has_excerpt_read_more' );
  • I already have this code in the functions.php file and it does not solve anything
    OK I think I know - you have to switch grid element template to one from theme.
    Edit your post grid and switch to Item Design tab and next select Apollo13 Post, see screen shot:
    686 x 476 - 30K
  • I don't need to select Apollo13 Post, i need to use the basic grid post
    OK, then use code I have gave you earlier.
    I have just tested it with basic grid post, and it hides our "read more".
    Place it in functions.php in child theme like on screen shot
    1048 x 523 - 21K
  • I already told you another day, when the Excerpt field of any post is empty "read more" appears if it has text, "read more" does not appear and I need it never to appear.
    See my home page, in "ÚLTIMES NOTÍCIES" posts
    Your code days ago that I have it.
    Yes, I understand that and I specially tested for it today before replying to you :-)
    I just suspect that maybe code is misplaced, or something that it doesn't work for you in case of Basic grid.
    Could you show me screen shot of your child theme functions.php, maybe I will be able to spot what might be wrong.
    Another idea: try removing another filter with this code:
        remove_filter(  'excerpt_more', 'apollo13framework_new_excerpt_more'  );
    This is only other place that produce such "read more" link.
  • ok, now it works correctly. Solve!
