Problems since update Rife Pro 2.3.1
in Rife Posts: 22
I have two layout/design problems since the update to Rife Pro Version: 2.3.1
1. A white line (border) appears under the header menu, and I can't figure out how to get rid of it. Please see image attached.
2. The image grid for the work/portfolio section has a small space between each image. There should be no space between images, but I don't find where to remove this space. Please see second image attached.
1095 x 150 - 28K
1846 x 1209 - 518K
    edited January 2019 Posts: 10,970
    Hey there:-)
    Very strange that it has appeared with this update. It could be caused by something else.
    Could you send me a link to your website so I could inspect it?
  • edited January 2019 Posts: 22
    Sorry, I forgot to include my website link. I will send it in a private message.
    Thanks for your assistance.
    Post edited by modern1 on
    As for border in the header, you should just refresh your settings as there was class name change due to a plugin conflict.
    Go to Customizer change any setting, back and forth and click Publish.
    As for margin, I believe you will have to set in your shortcode for works param margin="0".
    I believe this param was added later to this shortcode and therefore you got this default 10px margin.
    Sorry for unplanned issues!
    That worked. Your suggestions fixed both issues. Thank you.
