I have two layout/design problems since the update to Rife Pro Version: 2.3.1
1. A white line (border) appears under the header menu, and I can't figure out how to get rid of it. Please see image attached.
2. The image grid for the work/portfolio section has a small space between each image. There should be no space between images, but I don't find where to remove this space. Please see second image attached.
Very strange that it has appeared with this update. It could be caused by something else.
Could you send me a link to your website so I could inspect it?
Thanks for your assistance.
Go to Customizer change any setting, back and forth and click Publish.
As for margin, I believe you will have to set in your shortcode for works param
margin="0"
.I believe this param was added later to this shortcode and therefore you got this default 10px margin.
Sorry for unplanned issues!
