Problem with landing page
in FatMoon Posts: 7
hey! i decided to change my landing page from albums to my offer and it seems to indclude albums as well when i scroll down. i want my landing page to contain only my offer. is this a bug or do i just do something wrong?
my adress: http://zakrzewski.photography
wordpress 4.9.9
    It seems your support died 3 days ago. I will reply anyway, but please think about renewing: https://rifetheme.com/apollo13-framework/docs/getting-started/support-forum/expired-support/
    It seems you have set up your Albums list as the front page.
    You can either, move your new content to a new page and set this new page as the front page.
    Or you can disable "Albums list" template on your current front page https://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/adding-albums-list/
    That is not the case - that is why I report it, though my support ended. Thought that sharing something that seems like a bug is valuable to you as you can fix it for next releases.
    As for renewing it is almost certain that I will just buy more licences (already have 3) as I will need one for my bands page :)
    Anyway, to make things clear - I have my Oferta page set up as front page - and it is set to default template, not albums. I had Albumy set as a front page before and changed it recently. Now it displays BOTH Oferta AND Albumy, one after another, though according to the settings I have and your suggestion it should only display Oferta.
    Could you please send me temporary access to your WordPress so I could check there what is going on? Send it here on the forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please add LINK to topic it applies to.
    dex44 said: As for renewing it is almost certain that I will just buy more licences (already have 3) as I will need one for my bands page
    Wow, that is great!
    In theme settings for the front page, you have to change from Albums list to Page. https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/general-settings/front-page/
    It will solve it :-)
    thx! i did not expect that :D
