Posts not showing in WPBakery Page Builder post grid
After updating to Fatmoon 2.4.13 (from versjon: 1.2.2) the posts are missing on frontend when using the post grid element from WPBakery Page Builder (I am using the latest version; 6.8.0).
In the "item design" - "grid element template" I tried choosing both Fatmoon Post and Apollo13 Post, but the result is the same.
Is it not compatible anymore or should I use another element?
1434 x 388 - 67K
588 x 430 - 57K
1178 x 336 - 15K
    I suspect you are facing some JavaScript error and this is why it fails to load.
    Could you send me a link to a page where it doesn't; load?
    Hi! Yes, you will find it right before the footer of this page: https://hovikklstaging.wpengine.com/
    Btw, if I set the item design to Basic Grid: Default, the posts are showing, but without the theme's layout.
    For some reason, I did not have the Apollo13 Framework extensions installed. Installing it made the posts show.
    Thanks for your help!
    Bjorn
    Great to hear that. I forgot that you made pretty big upgrade that was few years apart :-)
