Hi - i normally don't look at iPhone when building sites but this one I built using Hypershot has the header and footer overlapping main image on the iPhone and I'm trying to understand if I can fix that in any way. I tried both Enabled and Permanent in the fixed header option - no difference.
Please show me link to your site. If you are using album there, then you should check option Fit Album and make it Fully visible http://apollo13.eu/docs/hypershot/#!/adding_album_add_new_album
Should help:-)
