Favicon & Footer
edited September 2014 in Adamant Posts: 9
Hi guys,
I'm having trouble finishing a website with Adamant. I can't change the favicon and the footer info, among others. In other templates has always been easy, but I can't change it in Adamant :S
Since I couldn't do it from the editor, I thought it might be 'Adamant options', but the panel is empty.
Please find attached a capture.
    do you get any javascript warnings or errors in javascript console?
    do you have any plugins installed other than default Adamants plugins?
  • Yes, of course. I have some non-Adamant plugins: Contact 7, iThemes Security and WP Maintenance Mode. I've deactivated them to test if it worked, but... maybe is not the problem.
    I don't understand what you mean about the JAVA console, sorry :(
    Can we fix it otherwise?
    Please send me login credencials. Do it via private message.
    I need a temporary access to admin panel, so i could help You.
  • Done!
    You have some big problem with server. A lot of scripts are not loaded - so a lot of functionalities are disabled.
    Please try to disable all extra plugins, just leave active those which are in Adamant package and check if it helps.
  • No, not work :(
    What kind of problem with the server ? I'm with hostalia.com , maybe I could send them an email to see if it's their fault and if they can fix it quickly.
    If not ( because their customer service is not very good ... ) , is there any other way to edit this? From PHP maybe?
