Hi, I inserted HTML in the footer in order to have Facebook icon. I copied the HTML line that is used for social icons on the header . It worked. The only thing is that on the footer is bigger than I would like. How can I control that? Is it possible? Thank you.
The footer's icon is bigger than the header's icon... The icon in the header I used the traditional way through hypershot panel. Compare with the image I linked.
I did a modification and put a social icon on the footer. They are on the left of the page but I would like chance the position of the social icon. Is it possible? Can you tell me how can I change that. I did a printscreen showing where the social icon is right now and where I would like to position it.
As I remember in Copyright text in this setting http://apollo13.eu/docs/hypershot/#!/main_settings_menu_footer_text You can insert HTML, co you can fro example use facebook follow button. You can also edit HTML in footer.php if you wish:-)
Thank you.
Anyway you can control this with CSS http://apollo13.eu/docs/hypershot/#!/modification_of_theme_changing_css
www.eduardobarillari.com.br
Custom CSS:
.copyright > a {If you will add more links there, then this will need to be changed.left: 50%;
margin-left: -12px;
position: absolute;
top: 0;
It worked with one but not with 2. I will put all the links I want and I get ask you again, ok?
