You can do it Panel, without using CSS. Title bar - you can switch it off in each page/post by setting option Title bar look to "off". If you need to do it globally you can use this custom CSS:
Not visible on mine and anything closely related is still ineffective. See the attached screenshot from the dashboard then screenshot 2 from the end users side.
:-) Check again in which group of fields you search, mainly look closely at top of my screen shot:-) There are two group of options and you are interested in second one. Just click on group title to hide it or open it.
Title bar - you can switch it off in each page/post by setting option Title bar look to "off". If you need to do it globally you can use this custom CSS: For Author section go to Blog options http://apollo13.eu/docs/fame/#!/blog_menu and turn off Author info in post.
If you are happy with this theme please don't forget to rate us on ThemeForest - it helps us a lot! Thanks! How to rate?
Maybe you mean something else? Please mark thing you want to hide on screen shot.
I hope this time you will find it :-)
