You know that in computer world milions on things could go wrong, so I don't think that listing all of them is possible here. However if you would post live link, that we could narrow that number, and find solution:-)
OK I can see the problem. Please tell me where you have put your custom CSS. We advice to add it in custom CSS plugin or child theme http://apollo13.eu/docs/hypershot/#!/modification_of_theme I am asking cause I want to know what exactly have you changed.
I just see that you are using sooooo old version of this theme, like 2 years old. There were so many fixes to menu during that time, you should definitely update theme, cause right now it can be issue that theme had after release.
Hi! It works fine, thank you very much...but how can I cahnge the submenu li position from the left to the right just to have this UOMO GALANTE MALANDRINO
For some strange reason theme calculates that there is no space on right side and this is why it shows submenu that way. It could be either this flag, or some of modifications that you did. Can you try to disable all of above and check if it will help?
Sure I know it But I have to solve this particular problem because it's a website for a fussy client
Here is the link
http://www.lodenism.com (italian version)
http://www.lodensim.com/eng (english version)
Best
.top-menu{
letter-spacing:1px;
I made the other changes (color and font-size) through Hypershot theme setting - menu section.
Best
Elisa
just updated the theme via ftp but nothing changes...
Other solutions?
Best
Elisa
UOMO
GALANTE
MALANDRINO
instead of this?
UOMO
GALANTE
MALANDRINO
Thank you very much
Best
Elisa
No chance to modify ii through css?
Best
We can do it by CSS but this will cover issue not solve it. However, as you wish :-)
Use this With regards.
Thanks for the css code...I tried several times but you won
Thanx
Elisa
