Hi Guys,
First of all, great theme, easy to use and great support. I am almost finished but got a few issues:
- The Partners (clients in the demo) images doesn't fit even when i make them smaller
- The Title of my works are above the picture instead of under
- The pictures in the collegues section are a little with space and the under photo is a bit right outset
- On my iphone the slider wont appear good, on a samsung it will
- If i make mor then 1 row in VC with a background like my contact and the things i sell on mobile only 1 row will be displayed with background and the other 2rows got a white background
- The pictures of the 3 column are very small on mobile.
My website is: www.mmcreaties.nl
Thanx a lot guys and keep up the good work!
thank You for the report. You're right, its a css bug. We'll fix this in upcoming update.
For now: go to Chillout Options >> Custom style and add this:
.people_item.simple .people_img { background-repeat: no-repeat; background-size: contain; }I can see one work item on your site, and the title is displayed under the image, just like on the demo page.
I have no clue where to find collegues section
what is the issue? can You post some screenshots?
Can you do it and then point this area to me - so I could take a look at it? Again - You're right, its a css bug. We'll fix this also.
.vc_col-sm-2 {
width: unset;
Its in underneed the MAAK KENNIS MET MM CREATIES part
See attachment 2 See attachment 3&4 only the middle row is with background the 3 others not. Only on phone not on tablet.
wont work see also attachment 3
5 more questions:
- i added the navigation anchors and it works fine but the Home button in the menu bar is always selected. How do i set this off?
- What is the purpose of the add/image/video in the works area instead of the featured image and what size is best to display it good on the blog and the works part on the main page.
- How do i get the social icons in my menu bar like fb and twitter?
- Is it possible to do SEO for every sepperate anchor or is only one page?
- What is the best way to install a update without losing content?
OK - that's odd... we'll investigate it, but it's most likely the problem of Revolution Slider itself... You should check the 'Cover background with image?' in 'Row' shortcode edit panel. change 'unset' into 'unset !important'. Today we'll release an update, so wait a moment, and it'll be fixed
Those are a media collection, that is not displayed by any of shortcodes. Those are displayed only when You open this Work/Blog item. What is the best size? Create a test page for yourself, create some works/posts in - let's say - 'test' category, and just play with it, You'll see what's the best for You.
First - define social links in Chillout Options >> Social settings
Next - Chillout Options >> Layout >> Header >> Display social icos in header?
Yep, each Navigation Anchor can be treated like separate link, so You can do SEO over it. You did not read the Documentation, did You?
please refer to: http://www.apollo13.eu/docs/chillout/#!/installation_update_update_theme
Only one small thing:
- The menubar is not straight at the page, the home is more to left en the contact also so it wont fit my page size check www.mmcreaties.nl
That's the way it is in this theme, the shield with logo is supposed to be in the middle.
And the social media icons at the top are nog displayed good a little bit wizzy
Should be: http://mmcreaties.nl/#a13_nava_id_314
Edit shortcode 'Works list' and change the 'Horizontal marigins of single item' and 'Vertical marigins of single item' parameters.
http://www.apollo13.eu/docs/chillout/#!/chillout_options_blog
What do You mean by 'Wizzy'?
And 4 small other questions:
- How to get the scrollbarr away on a people page
- How do i get such a bar on a team member profile like your page with for example webdesign 80%, Marketing 25% etc?
- Is it possible to use another image at the works portfolio at the top of the page with the title underneed it instead of the featured image? Cause now my feautered images are to big and wont fit propperly in the works bar. But when i dont use the featured image on the page it self the title will go up of it. At your page it automatic resize the pictures to fit in the grid on the main.
- The last works in the sidebar on the blog page dont align good to the right.
Thanx a lot, i like your theme so much and the support is outstanding!! did give you 5 stars!
'Progress Bar' shortcode Well - this is how it is supposed to be. If You want to change it - go to Chillout Options >> Custom Style and put this definition:
.widget_recent_works{ text-align: left; [or 'right' if You wish ;)] }All the Best.
the one next to the info text
How do i get this code, cause only can find this in the visual composer
Well... You could remove it, but this is how it was designed, and it would require some custom work in theme files.
This shortcode is an item available in Visual Composer.
The answer is: no, not at this moment of theme developement. Only Featured Image is displayed over the title.
If You're not satysfied with the way of displaying Featured Image in Work's grid - play with CSS in Chillout Options >> Custom Style.
Try this:
.g-link[data-post-type="work"] i { background-size: contain; background-repeat: no-repeat; }All the Best.
#logo { left: calc(50% - 82px) !important; }OR
give me access to admin panel. If this is ok for You, just send me login credentials, but REMEMBER to do it via Private Message (click my nick-name and from left menu click 'send surgeon message' link)
I think there's little bug inside dummy data import file, but now it's ok without any tricks.
Sorry for the incoviniance
To change it put this definition to Custom Style:
#a13-full-photos img { display: block; height: auto; margin: auto; position: relative; }All the Best.
See attachment
Even when i try to resize the image(tried it 5 times) the image still displayed for the half. You dont see the Wheels of the car on this page.
#a13-full-photos img { display: block; height: auto; width: auto; margin: auto; position: relative; }All the Best.
Please tell me what are You expecting?
What size of image You would like to have after opening Work?
And cant figure out how to make a shortcode for that progress bar.
but the picture dont even after your code! see attachment
Just want the same sizes as the live preview. IF you can tell me those px i can make pictures on that perfect size on photoshop.
I added a photo of the page and the normal photo
You have now image 800*600, so You must change this parameter to 600.
If You want to fit You image into current layout - it should have 450px height.
As for Visual Composer itself - look here: http://vc.wpbakery.com/video-academy/
Lots of tutorials.
For example in the live preview if you click on a team member you see this under the text
Go to Left Menu >> Setting >> Visual Composer and check 'people in 'Content types' section.
The only last thing what need to be fixed is the appereance of the slider layers on mobile phones, now it not fit.
For all the other things thanx a lot!
- What kind plugin can i use to do the SEO for seperate pages. With the most plugins i only can do the SEO of the home page where all my pages are under.
This is OnePage design - so You get one page, right?
And one other question, can i change the word Similar Works (if i open a Works item at the bottom)?
Kind Regards
it's not the bug.
This is how tha layout is collapsing into mobile mode.
You've put the image and its decroption into separate layout cells. Try to solve your desing in different way, try to keep image and its description within one column.
On all other devices it works well if hold me phone on the side it gives no problem only on the ipad.
See attachment for my setup of that part
