In Panel in option Menu links color you have set white color but with opacity and it looks like this rgba(255, 255, 255, 0.6); . Change this 0.6 to 1 and you will be fine :-)
Now, in the same train of thought, how do I make it so the link the user clicks on changes color when they are on that page?
Example: if user clicks 'our purpose' link, then on the 'our purpose' page, the 'our purpose' link at the top is now a different color (to indicate he is on that page)?
Also when the user hovers over a link I would want that color to change.
Hi - yes I had actually tried that mister smarty pants the problem is as you can see at www.impactconnector.com - 'how it works' is now grey even though that's just an anchor link. I would expect all links white when you go to the main page.
So I should have asked the question like this: how do you avoid the anchor link reacting to the 'menu links active hover' and becoming grey?
. Change this0.6
to1
and you will be fine :-)With kind regards.
Thank you!
Your link is marked on hompage cause wordpress recognize that this just anchor on your hompage, and it marks it.
We can force it with custom CSS to make it white on homepage: With kind regards.
