I wanted to ask if there is any option to set the work item to lead to a page instead of a lightbox. Or if I can do this with a single image added in the visual composer? When I add an url into image link field, only lightbox appears afterwards (like in the screenshot).
Thank you
You can always add a nice looking link into the Work Item content.
Does it satisfy You?
Thank you
the 'Works List' shortcode has 'Display as gallery?' parameter. Just uncheck it.
Is there any way how to achieve this please?
You've done it manually, right?
To block displaying images with lightbox You should add 'block_cb' class to the image.
I made the image look like a work item with custom css, you can see it here: http://ahojtadygema.cz/quixdeko in the 'decoration' section.
I attached setting of my image.
It's not working with the 'Single Image' shortcode.
I'll fix that, wait few day (i think untill monday) for next update.
I've checked again.
Have You updated all plugins? Something wierd is going on...
I could use a login credentials to admin panel. If it's ok for You - send it only via private message.
Problem solved?
