Work item leading to a new page
edited February 2015 in Chillout Posts: 15
I wanted to ask if there is any option to set the work item to lead to a page instead of a lightbox. Or if I can do this with a single image added in the visual composer? When I add an url into image link field, only lightbox appears afterwards (like in the screenshot).
Thank you
    You can always add a nice looking link into the Work Item content.
    Does it satisfy You?
  • How can I do that without the lightbox popping up please?
    Thank you
    the 'Works List' shortcode has 'Display as gallery?' parameter. Just uncheck it.
  • Hi, sorry for bothering you so much, but that also displays the content in a popup window. I need to somehow link it to another page in wordpress. As I said I also tried adding an image and setting its url adress, but it only gives me that error.
    Is there any way how to achieve this please?
    But it's not a Work Item at all...
    You've done it manually, right?
    To block displaying images with lightbox You should add 'block_cb' class to the image.
  • It doesn't seem to work:/ I also downloaded the latest theme version.
    I made the image look like a work item with custom css, you can see it here: http://ahojtadygema.cz/quixdeko in the 'decoration' section.
    I attached setting of my image.
    1200 x 1326 - 208K
    Ok, this 'block_cb' class was ment for content of 'Text Block' shortcode...
    It's not working with the 'Single Image' shortcode.
    I'll fix that, wait few day (i think untill monday) for next update.
    Hello again,
    I've checked again.
    Have You updated all plugins? Something wierd is going on...
    I could use a login credentials to admin panel. If it's ok for You - send it only via private message.
  • Thank you!
    Problem solved?
  • Yes, it's working, thank you:]
