Text Box linked to Work Item - lightbox issues
edited February 2015 in Chillout Posts: 12
Hi, sorry to pester you again..
Thanks, the recent update really helped sort out some issues we were experiencing with columns.
Are you able to assist with something we are trying to achieve?
I would like to link a work item lightbox from a text box on my home page which has an image in it (I'd like it to open as a light box for SEO purposes rather than a link to another page).
I have wrapped the image in the text box in <a href> and linked it to the work item previously created. However when I go to preview it - the light box takes a while to load, and once loaded it doesn't look anything like the lightbox/work item on the demo. (Which we really like the style of), and our content inside the light box is off centre and cut off.
Is there a way to achieve this or… Is there a way we can style the existing work item widget to look like the text box I mention above on the home page, with independent styling on the actual work page?
See attached screen shot of light box when open showing the off centre content.
website where you can try the active link - www.pmngroup.com/wordpress/
(The text box with the active link is the pink box - advertising & marketing)
    Well...
    everything is possible, but this what You are asking for is a custom work.
    Why don't You use 'Works list' shorcode - You'd get exactly what You want?
