Could you be more precise? Colour of what? If you mean all links -> wp-content/themes/airborn/style-def.css line 145 If you mean menu -> Backend ->Airborn->Colors
1- I have an issue with the images in the portfolio, it doesn't show any images after i add the images the small pic and the big one. what is the problem? is there any size or something else to fix that...
2- I have 1.2 version I just got it week days ago so how I can update to the new one, If I update it, I'll lose something or it's gonna be the same information in my page.
3- the side bar (banner) I add 10 side bar, but in the bottom of the bar the Dot it's not in the center.
2- I read it now yes but the reason why I'm asking is each time I upload the version it shows on the themes Manage in backend the version is 1.2 it doesn't change to 1.2.5 I just download the last file and I update in my themes and still 1.2.
- I still have my biggest issue with the images why it doesn't show on my portfolio or in my blog. I'm really tired I spend all day just for this and it doesn't looks like what you have in the demo.
Ex: If I add new post to my blog ok. it should show in my front homepage under the Latest from blog the text and pic. but it shows only the text with out any pic!!! and the same in the portfolio sec!!
Did you uploaded featured image as i adviced? Go to My portfolio->Edit some portfolio item ... ooo hell, just check this image: http://support.apollo13.eu/uploads/featured.jpg Hope this helps.
About version number : don't worry its not showing, it is our fault(forgot to upgrade numeration).
it's work now thanks, the issue was when I upgrade the last version it doesn't active direct I have to go back to the them and active it from there to work.
but where can I find the Backend to change the color of the menu?
appreciate your help
check the att pic please.
Hi there.
Firstly update, do it before any other progress.
About updating http://apollo13.eu/docs/airborn/#!/installation_update You shouldn't loose anything, but just in case make backup.
1) http://apollo13.eu/docs/airborn/#!/portfolio use featured image to represent each project.
2) Answered
3) Attachment didn't work, please provide other way to view situation, cause I don't get what you mean.
4- in the Blog page how can keep in the beginning just short text with pic and if he click on any post it will open all the text with photos
Thanks a lot.
2- I install the plug in for my WP but where can I find the last version 1.2.5 to update it.
3- For the att below link for the issue:
Thanks a lot for your fast replay.
2 ) Did you read topic Before you ask READ THIS :-). New version is available there where you bought theme;-)
3) Still don't get it. Sied bar? You mean slide show also known as Slider? :-) In your picture I see that dots are centered, so what is the issue?
EDIT:
Yes know I see. There is fixed margin where dots start, not centered. We will fix this with next update. Thanks for support.
Screenshot: http://www.omranstudio.com/upload/12.png
3- oh I'm glad for that.
My Link: http://www.omranstudio.com/v5
http://www.omranstudio.com/upload/Picture72.png
http://www.omranstudio.com/upload/Picture74.png
I tried all the shortcode and it's the same issue.
Please any help.
Hope this helps.
everything now is good with me Big thanks really
After I update the last Version 1.2.6 and the contact form still doesn't work.
I use Firefox.
and it's work on Safari only!
Any help??
http://www.omranstudio.com/upload/Picture86.png
Thanks a lot
how can I make all the Paragraph font bigger.
http://www.omranstudio.com/upload/Picture88.png
Font size globaly: file style-def.css in airborn directory, line 136
font-size:12px;. Change to whatever you like.Hope that helps.
