I have a site in development using the Blame theme (that I love)
http://hrprint2.theprojectfoxhosting.com/. But the mega menu isn't sufficient for what I need to do. I would like to use something like Ubermenu (sorry) but it completely conflicts and renders the whole site a giant jumble of death. Can you suggest a way to remove mega menu and replace it with Uber or suggest a different mega menu plugin that you feels works well?
Sorry!
Jennifer
No need to feel sorry ;-)
Unfortunately I don't have access to ubermenu, but I know that every change(addition) to core wordpress menu, makes this plugin impossible to work.
If you will help me, then we can make blame compatible with ubermenu by switching off all additions to menu. If all will work good then I will add such option to theme.
So, go to blame/advance/apollo13.php line ~125 and remove this
require_once (A13_TPL_ADV_DIR . '/mega_menu.php');
Check how it is doing, and if you see some styling issues then post live link and I would verify what and why :-)
I went into filezilla and did a search for mega_menu.php.
Line 125 is this:
add_query_arg(
So I did a search.
The words require_once do not appear in the file.
The words A13_TPL_ADV_DIR do not appear in the file.
So I went to the zip file I downloaded from themeforest and I found the original file in blame/advance/mega_menu.php and it doesn't exist there either.
Here is the original file...untouched from the blame theme I downloaded...
So Confused!
Jennifer
I must have been in sleep, cause I always read what I write and still I let such bug in my reply.
Sorry once again:-) Wow, thanks for all you appreciation:-)
I deleted that line of code but the problem is the same. I can load UberMenu but it just doesn't work correctly in the site. For example when you scroll down the menu won't let you access any of the drop downs.
I'm sorry to keep bothering you!
Jennifer
I have deactivated W3 Cache plugin - such plugins should be activated when you are done with messing with site layout :-)
To fix position of sub-menus I have enabled option Bound Submenu To ->
Inner menu bar width , check screen shot.
For drop down while in "scrolling menu" it required custom coding, but ended relatively easy:-)
Hope now will everything work for you. If not, you know where to find me:-)
It's amazing that you added support for uberMenu. Will you have an update that I should (or shouldn't) install?
I have another question...should I start a new thread?
The question is this...when you scroll down on the site the header pushes the text to the far left, which makes the menu double into two lines. Is there a way to get the header text (Online. In Print. In Person. -- 613-966-2323) which is in the blue box to remain above the menu instead of going to the side?
Again thank you for everything -- I just sold your theme to another customer. They build custom wood frame homes. He'll be downloading it shortly at my request.
Thank you again for everything!
Jennifer
Use such custom CSS: Should do the trick.
