Plugins
edited March 2015 in Chillout Posts: 4
I have purchased and installed the Chillout theme, however it seems to have dependent Plugins that need to be installed in order for the Theme to work. But none of the plugins are available to install (see attached screenshot) nor can they be searched for and installed via the main WP Plugin page. Apparently the Theme's Plugins are located in a Private Repository which can not be accessed - could you advise as to how I can access those to solve the problem?
    Check all checkbox on the left, and pick 'Install' from 'Bulk actions', and then 'Apply'
  • Hi yes that's the first thing I did, but a message comes back to say 'failed to download'. This message appears if you try to install all of them together or one at a time.
    OK,
    so You need to install them manually:
    When You unpack the theme package You get the folder named 'chillout' - open it, go to location 'chillout\inc\plugins\' the plugin package is here.
    As for installing plugins manually please refer to: http://codex.wordpress.org/Managing_Plugins
  • That folder is not in the zipped up Chillout file structure that was received. I can not install manually either because they can not be found on the WP Plugin system. Can you send the plugins to us directly?
  • Hi just checking that you received the question above? Could you advise as to when you can respond and/or send the files as we need to resolve the problem ASAP. Thanks,
    edited March 2015 Posts: 10,970
    I believe you have plugins in theme, just check on ftp('wp-content/themes/chillout/inc/plugins') or in ZIP file that you have from theme forest go to another zip, this time with theme, and then follow 'chillout\inc\plugins\'. I believe this is what surgeon meant.
