When into my grid element builder and add a custom field. The pop-up settings box gives me the following fatal error :
Catchable fatal error: Argument 1 passed to Vc_Edit_Form_Fields::setSettings() must be of the type array, null given, called in /home/micdri10/EXTREMESOUTHAMERICA.COM/wp-content/plugins/js_composer/include/classes/editors/class-vc-edit-form-fields.php on line 47 and defined in /home/micdri10/EXTREMESOUTHAMERICA.COM/wp-content/plugins/js_composer/include/classes/editors/class-vc-edit-form-fields.php on line 68
Isn't this thing connected to your other topic http://support.apollo13.eu/discussion/3193/warning-in-regards-to-formatting-php#latest ?
It might also be issue of VC. Have you tested this with default Wordpress theme?
I found same issue here http://codecanyon.net/item/visual-composer-page-builder-for-wordpress/242431/comments?page=361#comment_9270778
I have found few people reporting this issue, like here for example http://support.vibethemes.com/support/discussions/topics/1000059118
and next here http://allindiachannel.com/how-to-update-visual-composer-in-news-paper-wordpress-theme/
Does VC work when you switch off debug mode?
In that case this is clearly Visual Composer issue. Let me take a look in their code, and see if I can propose any patch for you, before they fix their plugin. I will reply soon.
Hope this also work for you.
