Hi Guys,
after the last 5 updates my page is whole mess. I cant use visual composer and the whole page is weird.
Even after updating visual composer it still give me the warning please update visual composer.
See attachments
Next to that my logo is not in the center anymore on mobiles?
as for Visual Composer update. This is a problem, and apparently You just can't do it automatically. This plugin must be updated manually, we hope next version of Visual Composer will be free from this kind of glitches.
As for messy behaviour of Composer now - perhaps this problem will vanish after manuall update, but there can be a problem with coexistance of SEO by Yoast and Visual Composer.
please inform us if the problem persist after manual updating the Visual Composer plugin.
Next to that the messy behaviour is only a problem since 3 updates a go therefore there wasnt any problem.
Also my logo is not displayed in a correct way on mobile its to much down.
What is the problem that with every update there will be new problems. I have a business to run and with al this kind of things i can't work well and it is not a good display for possible customers to!
We had to update Visual Composer for it was buggy in previous version, and now apparently it has a problem with coexistance with SEO by Yoast.
This is happening because of combinations of two parameters:
1. shrink logo's shield
2. logo image top margin
try to reduce anyone of above - this should help.
One more question is it possible to centre a whole column on mobile only? now al the items are alligned left and all the other elements to center.
See attachement
Now it's shrinking to 0, it has 0px width.
It's simply empty now.
'Logo size after shrink'. '1' means no shrink, '0.5' means shrink to 50% of original size, '0' means shrink to 0.
I cant get it correct on mobile, can you please give me the good numbers or maybe change it when i send you the login?
the sidebar is working good, there's simply nothing to display in it. try to add simple widget into it (let's say calendar) and You'll see it's working. Perhaps You didn't set the 'Contact Info' plugin correctly.
as for shrinking logo - I set to 0.75. try now, check if it suits You. If not change to whatever You want.
