WHOPPS!!!! I worked it out with looking. I'm also wondering how I can do the following:
1) Make the box bigger on page like for example: 'News' to fit the Layout style of wide from the logo to end of menu. 2) How to change the box color on the page like it's 'Black' 3) How to hide the homepage video player controls like video bar / sound e.g. 4) How to repeat videos on the homepage as we are only using 1 video for the homepage. 5) How to remove the line in the attached file below in the black box.
If you have more then one case to talk about then please add every case in separate topic(read more here), cause if this topic will have more then 3 answers, it will make chaos by answering to different points of first question. I believe you can imagine this :-)
Please also add screen shots/live links to every case, cause I can't answer to any of your points.
This topic should be helpful http://support.apollo13.eu/discussion/1814/removing-hide-layout-and-play-button-from-footer/p1
Many Thanks,
The Team Of JM
For last point use this custom CSS:
.post-info{With kind regards.border-top: none;
