Hi Surgeon / angela , it work for us, in file script.js of plugin chillout
just change in all file for tmp_h outerHeight() for height () and for block scroll range just round values because firefox bug with value 99.99999 exemple var tmp_h = $(".work_slide").find('.'+post_type+'_slide_content_wrapper').height(); /// /// /// window.A13P.set_scroll_range( (Math.round($('#work_modal_port').offset().top)), (Math.round($('#work_modal_port').offset().top + tmp_h)) );
Hello. In changelog (http://www.apollo13.eu/changelog/chillout/index.html) there's a info: ***=== NEED TO UPDATE 'Visual Composer extend by Apollo13 for Chillout' PLUGIN ===*** ***=== NEED TO UPDATE 'Chillout Plugin' PLUGIN ===*** Please update those plugins, the issue You've reported is fixed.
exemple
hope its ok.
My version to wordpress is 4.2.2
