Hello Daniel I want to place my menu 1 ) vertically 2) in my footer 3) on the right side of the page and 4) as low as my logo is. Is this possible? I tried placing the menu in a widget in all separate footer areas but they end up below my slider and above my footer on danceatwork.nl. thanks! Horst
I don't see any menu there now. Have you removed it?
You can try to put your logo in widget (Text widget for example) and then next widget could be menu.
It would be good to see on screen shot what you wish to achieve.
if this is how you want your footer, then try this cusotm CSS:
.foot-widgets .col {
Should do it ;-)width: 48%;
.foot-widgets .col-2 {
text-align: right;
Great it worked for you.
Have a great weekend!
