Light bulb gone, background colour and uploader doesn't seem to be working from Library.
edited August 2012 in Spaceship Posts: 26
I've got a couple of things that I can't figure out, if you can help I would really appreciate it.
1. After we sorted out being able to drag and drop widgets in my last discussion the light bulb disappeared.
2. I mistakenly entered a value in to the background colour and now it's white.Doh. How can I get it back to black?
3. When I try to import pics from my media library in to an album the library doesn't come up in the window.
Cheers
jonashford.com
Info.jon.ashford@gmail.com
    Hi Jon23
    Could please link your site? Give version of your theme? Just follow http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#Item_1
    1. Check is glass effect is on http://apollo13.eu/docs/spaceship/#!/glass_effect_menu
    2. Just set it back to black. I don't know what is the case here? http://apollo13.eu/docs/spaceship/#!/appearance_menu_main_appearance_settings
    3. If you have new version of spaceship try to refresh cache of browser, maybe old files in cache are holding back. Try CTRL + f5 while in WP admin panel.
    Hello Air,
    Sorry I left all the important details out before. I'm still a bit new toall this as you have probably already guessed. Thank you for your patience.
    http://www.jonashford.com/wp-admin/
    - I'm still on version 1.0. Tried to upload new version before but it took ages and didn't work.
    - Plugins screen grab attached
    - Wordpress version 3.4.1
    I've refreshed the cache, but still have the uploader problem and I have set the colour to black but it does not respond and stays white - see attachment.
    600 x 599 - 95K
    830 x 711 - 26K
    772 x 460 - 54K
    Correction. I've changed the background colour. Just decided to work this time.
    I have used old data you gave me to login and I found that Track That Stat plugin is interfering with that media list, but I really don't know why. I will try to check this case, but for now I have deactivated that plugin on your site. You can activate it after you are done with adding images/media form media library:-)
    Fantastic, thank you.
