I am in process to build a website using Blame theme. I have created almost all the pages, but now when I updated the theme to 1.5 is messing the layout, here is the after and before txt of page body
As you can see in attachment, there is lots of repated backgroud and lines
Here is the page content
***************** Before***************** (screenshot http://projects.magicway.org/wp-content/uploads/2015/09/before.png)
[vc_row full_width="1" full_width_content="1" bg_position="tl" bg_repeat="no-repeat" parallax_type="tb" parallax_speed="1" bg_video_position="top" bg_video_parallax="none"][vc_column width="1/1"][rev_slider_vc alias="homepage"][a13_hellotext upper_text="The services " lower_text="that we provide " title_align="align_center" title_size="size_big"][vc_separator color="grey" style="empty"][vc_row_inner][vc_column_inner width="1/3"][a13_title_with_icon title="Software Development" title_size="h3" icon_color="blue" title_align="center" a13_fa_icon="desktop"][/vc_column_inner][vc_column_inner width="1/3"][a13_title_with_icon title="Website Development" title_size="h3" icon_color="blue" title_align="center" a13_fa_icon="globe"][/vc_column_inner][vc_column_inner width="1/3"][a13_title_with_icon title="UX Design" title_size="h3" icon_color="blue" title_align="center" a13_fa_icon="child"][/vc_column_inner][vc_column_inner][vc_separator color="grey" style="empty"][/vc_column_inner][/vc_row_inner][vc_row_inner][vc_column_inner width="1/3"][a13_title_with_icon title="App Development" title_size="h3" icon_color="blue" title_align="center" a13_fa_icon="mobile-phone"].........
***************** After ***************** (screenshot http://projects.magicway.org/wp-content/uploads/2015/09/after.png)
[vc_row full_width="1" full_width_content="1"][vc_column][rev_slider_vc][a13_hellotext upper_text="The services " lower_text="that we provide "][vc_separator][vc_row_inner][vc_column_inner width="1/3"][a13_title_with_icon title="Software Development" title_size="h3" a13_fa_icon="desktop" title_align="center"][/vc_column_inner][vc_column_inner width="1/3"][a13_title_with_icon title="Website Development" title_size="h3" a13_fa_icon="globe" title_align="center"][/vc_column_inner][vc_column_inner width="1/3"][a13_title_with_icon title="UX Design" title_size="h3" a13_fa_icon="child" title_align="center"][/vc_column_inner][vc_column_inner]........
I am stuck here since i cant make any changes, If i do every-page is getting messed up. Please help asap.
If you need access please email me.
Have you update Visual composer while doing update?
Can you post live link to your site so I could see what strange style is doing this?
I would opt to roll back, as your issue with drag and drop might be caused by something else. I think it would be easier to solve what is messing VC drag & drop function then find out, why it is clearing your shortcodes.
Second idea: if you edit this rows that was affected and set once again background to "no repeat", would this stick after save?
I will investigate what may be causing this clear of shortcodes, cause it looks like some config is not read.
Wish me luck.
Take this attached file, unzip it, and upload whole directory to wp-content/theme/blame/ overwriting current vc_templates directory.
I am not 100% sure everything will work flawlessly now, but it should.
Please try it and report me back.
It should work with new VC 4.6.2 and 4.7.0
Thanks for your help, Last one fixed the background repeat, but separator is still having lines, on empty-line preset also. Please see if you can fix it.
Thanks for info!
