Change Gif Image in Works
edited August 2014 in Adamant Posts: 7
I want to change the gif rotating arrows image which shows up when i click open any of the Work Item.
How can i do that ? Where to change ?
Image attached.
Regards
Rajiv
    it's not a GIF image, it is rotating Font Awesome icon.
    So you can modify it with css only.
    Here you have full list of available icons:
    http://fortawesome.github.io/Font-Awesome/icons/
    If you can find an icon for you - just post me the name of this icon, i'll prepare custom css for you.
  • hi,
    it is possible to change the color of this font icon?And how to do that?
    Regards
    Corentin
    just go to AdamantOptions>>Custom Style and enter color definition for .ajax_loader class.
  • i can't figure hox to enter a valid css text to change the color to some kind of orange...:/ can you help me?
    thanks!
    use this: http://www.colorpicker.com/
    set the color You want and copy color code from input field above color picker.
    example: http://www.colorpicker.com/ffc012
  • thank you, but my problem is that i don't know what to type in the custom style column to change the ajax loader color...
    You are talking about the icon from the very first post?
  • yes sorry i m talking about the rotating awesome font
    ok,
    the css class You are looking for is '.ajax_loader'.
    Go to Adamant Options >> Custom Style and place there definition like this
    .ajax_loader{
    color: #ffc012;
  • Many thanks ! This works.
