.ajax_loader{color: #ffc012;}
it's not a GIF image, it is rotating Font Awesome icon.
So you can modify it with css only.
Here you have full list of available icons:
http://fortawesome.github.io/Font-Awesome/icons/
If you can find an icon for you - just post me the name of this icon, i'll prepare custom css for you.
it is possible to change the color of this font icon?And how to do that?
Regards
Corentin
just go to AdamantOptions>>Custom Style and enter color definition for .ajax_loader class.
thanks!
set the color You want and copy color code from input field above color picker.
example: http://www.colorpicker.com/ffc012
the css class You are looking for is '.ajax_loader'.
Go to Adamant Options >> Custom Style and place there definition like this
