Mobile Menu/Log not working properly
Hello would you be able to help me with an issue I am having while the website is in mobile mode. I have attached images with notes so you have a better idea of what I am talking about.
Thank you!
Yog
  • also my website is http://www.yogjoshi.com
    For now please deactivate AJAX mode.
    Next thing - have you made any modifications to code?
    Do you have any special plugins installed?
  • Turning off AJAX did the trick! Thank you very much!! I absolutely love this theme you guys have created it. It's truly wonderful!
    Yog
  • Hello there,
    I have a big issue with my menu...
    May be i've done something wrong (even if i never touched the code or css).
    The website works perfectly on PC but the menu doesn't work on mobile devices : website crashes after clicking on any menu item.
    I tried to desactivate AJAX mode, but the problem still happens.
    Could you please help me.
    my website is : www.arnoweil.info
    Many thanks,
    a
    Hello there:-)
    I have just tested your site on iPad and iPhone and I don't see any issue with it.
    What device were you testing your site on?
  • Hello
    Finally, I disabled the two AJAX buttons in the customize menu... (first I disabled only one then the otherone, but never the two together). Indeed, now it's working very well :-)
    But can you explain (or give a link which explains) what are the options I disabled in turning those 2 options off ?
    Many thanxx
    Best
    Sure, read here http://apollo13.eu/docs/photon/#!/advanced_menu
