Hi Guys,
We are now 5 updates further and still the issue with yoast and the theme is there! I just created a new page but are unable to enter keywoards in yoast cause it mash ups the whole page! It getting very frustrated now cause i want to enter correct SEO on a certain page! Now a keywoard of another page is set cause i copied it and are unable to change it! See attachment:S
I know that when You put keyword then Visual Coposer has some serious problems to work correctly.
For me worked server upgrade, specially PHP version. What PHP version do You have on your hosting?
Another trick is to disable SEO by Yoast plugin while You're editing pages and when You finished enable it and enter all SEO data.
i tried this
But as you can see in the screenshot my whole SEO YOAST field is grey.So i cant do anything with seo on the site anymore. This is the only theme what cause this problems with visual composer cause on all other themes vc works fine with yoast. So please come with a good solution for this cause it frustrates me very much. I pay for a theme wich should support such kind of SEO plugins!
after my first reply I started to digg deeper, and I think I've found the solution, but I need to run some more tests so please wait day or two, I'll let You know.
CSS definitions that make title invisible are done by You, and I will not mess around with code You wrote. Simply remove it or modify.
Sorry, but it's not a bug.
Like I told You - after this report (september 28th) I've noticed that Work items look like now, without titles.
This is not done by me.
I don't know whodone this.
This is inside style.css file of child theme.
It's not a bug.
I didn't touch this file.
I'm not touching it at the moment.
I'll not touch it.
In line number 24 there is a definition which is doing this. Change it, remove it, do whatever You want.
It's not a bug.
