hi i am getting a home page is not indexable issue.. (major) saying that the page has a canonical url set to
http://...../album/full-with-slider/HTML: <metarobots='noindex'
robots.txt:-Tag: noindex
robots.txt: User-agent: *Dissalow/
HTML: ,link rel='canonical'/
And No H1 tag...
how good is the theme for SEO?
ps how do you protect and album.
That is the problem with custom post type, when it is setup as front page. Wordpress don't have native solution for putting custom post type as front page, and this is why canonical link is wrong.
BUT I am now searching for solution...
I think you could use SEO Yoast plugin as most users does when they are really interested in SEO stuff and there you can change canonical links http://kb.yoast.com/article/148-canonical-urls-in-wordpress-seo
For solution in theme, I don't see way to do it, that wouldn't break SEO plugins. However I will dig in code for few more minutes:-)
In album there is no use/place for
h1
tag. It is used in title bar on other pages. I believe we could put there hidden visually title of album, but it is not always desired. If you want I can help you make this simple modification.With kind regards.
1. Do you see it on your homepage or other sub page?
2. Try logging out of wordpress and test your site again.
any thought on the other things mentioned..
regards Tai
