- I need to change the limit of team of 4 to 5 people on the same line! -- Accurate images to be smaller. It must have 5 on the same line !!!!!!! --- I need help please!
this will allow You to fit 5 items in Team shortcode, but those items should have 'Item size in grid view' parameter set to '1x1' or '1x2' or '1x3' or '1x4' (can be found in metaboxes in people edit panel) warning: this will affect Work Items also, but only when their size is set to '1x1' or '1x2' or '1x3' or '1x4'
So - please - be patient.
please go to Chillout Options >> Custom Style and paste this definition: this will allow You to fit 5 items in Team shortcode, but those items should have 'Item size in grid view' parameter set to '1x1' or '1x2' or '1x3' or '1x4' (can be found in metaboxes in people edit panel)
We will launch the site!
