I have some difficulties and will be grateful if you could please help.
1. Links are not same with the menu. Example. I have "upcoming" button in menu, but in the link says "blog". or "credits" in menu, "resume" in link. See link please.
http://www.matthewgould.website/#a13_ResumeAlso any possibility to have link without "#a13"
2. Some of the menu buttons doesn't work on top right corner menu. See link above please.
3. Twitter feed doesn't show up on website. I have done all consumer Key etc needed.
What You have in tiles is a 'Blog' Navigation Anchor with title changed in Visual Composer.
What You should do:
1. while editing Home Page find the row containing 'Upcommin' content block.
2. edit the settings of this row
3. go to 'General' tab and change 'Navigation anchor.' parameter to 'Upcoming'. yes, but in the future, not precise date.
Yes, Upcoming and Credits. It's because those are trying to link to not existing elements on the page.
You need to chage 'Navigation anchor' parameter of each content block (while editing Home Page) to those used in navigation menu.
Go to Left Menu >> Appearance >> Widgets, and add Twitter Widget Pro to Footer Widget Area.
In the Navigation anchor there are only the ones (blog, portfolio etc) you have put in demo theme. How can I add "upcoming" to navigation anchor? Alternatively I tried to give a "Row ID" it worked but in the link it shows some numbers and top menu still doesn't work. Any way I can sort this out?
'Adding new Navigation Anchor is trivial. Just add title and save this post.'
look at screen-shot.
https://nimbus.everhelper.me/client/notes/share/333162/6nONank7iTQC9UTGmUPiiBffxX0TVeQ6/
