I recently cloned the home page. I was plan on making the works section a separate page. I deleted a lot of the content on the cloned page. When I went back to my normal "Home Page" the Default index page of the site, my menu links were messed up. The home page is now home-2 and the Services linked turned into the /works url. Causing my sites menu to be completely screwed up. I checked into the navigation anchors and the menus and could not find where to fix the issue.
http://www.pixelmonster.us/As you can see the "permalinks" on the navigation anchors are been changed. Please help!
http://i.imgur.com/vgjswpH.pngThanks.
Second - the mess is quite interesting, I could use a login credentials to take a closer look. If it's ok for You - please send me login credentials via private message.
I've sent you login creds via a PM.
I'll get back to You soon.
I have noticed a couple more problems since I cloned the home page (front page.) When I now try to edit the home page via visual composer it hangs on "loading.." (see at the top right of screen shot.)
I've also noticed under the Chillout Options it's showing Work (portfolio) which was the name of the page I duplicated from the home page.
http://i.imgur.com/kCkNTh0.png
Any update as to why this is happening?
As long as the login credentials You gave me are valid - I'll take a look at it.
This should be not a problem at all.
After saving the home page the main menu seems to be fixed. I don't know if you did this or the homepage update did it. However I believe we're all good now.
